don't waste your money... i doubt you'll get more then 100mhz truely stable and thats with effort. palos are truely lousy for oc in my experience. new tbred chips cost next to nothing, better to save money for that. its only worth buying a nicer heatsink if it costs less then the difference in cost of a chip as fast as the overclock.
So any cheap processor you recomend? My friend just got one of those unlocked Barton 2500+ and intend to overclock it to a 3000+ speed or something like that.
I have searched over the web and it says my motherboard with a bios flash will be able to handle a barton
I installed my Cooler Master heatsink last night, and its working GREAT with my pc overclocked to 2500+, planning on going higher within couple of more days.
the heatsink is huge tho lol. it's well worth my $29.99. temp's at 35.
