need new fan for power supply
pnkflyd51
Hello-
My power supply fan burned out. It's a 80 mm 12V fan. It doesn't use the hard drive connector, it is the female end of a two prong plug.
Anyone know of a site where I can buy a super quiet fan?
Thanks much!
Any of the sunon 80mm fans should do you. I've often used the 4pin conncetors when replacing the fan (just run the wire out with the bundle and plug it in) or you could get a panaflo w/out a connector on and do some soldering.
