NEED NEW COMPUTER! NEED HELP BUILDING!
krashx6
ok, like topic says. Im buying a new computer sorta. Ive got around $400-500 and i plan on buying...
motherboard
ram
processor
case
Just those 4 things, but i need to know ALL you can tell me about what the 4 BEST for that price range i have would be. i wanted atleast 256 ram by the way... 512 would be awsome.... So post EVERYTHING you can tell me.
All from Newegg unless stated otherwise....
ASUS A7V133 mobo $105
Crucial CAS 2 PC133 SDRAM $33.29 (Crucial.com)
Athlon 1.33GHz AYHJA stepping $106
"Enermax" (Antec SX1030 with 330W Enermax PS) $99
have fun
I was told these would be good:
Amd 1500+/266 FSB Athlon XP 1500+ Athlon XP 1500+/ 1.33GHz - $120
ECS K7S5A - $62
512 pc 2100 crucial cas 2.5 - $65
basic case - $60
...This sound good? can i get somone to like rate this stuff or gimmie reviews or anything at all?
don't go for the 'basic' case, you'll kick yourself later after you cut off a few fingers. IMHO the Antec sx1040 is a great deal, and worth every penny (it's only $30 more than a plain old ATX case)
Correct me if I'm wrong, but the only difference between the 1040 and the 840 models from Antec is the locking front-cover and an inch or two more space in the 1040? Seems unnecessary.
krashx, what are you going to be using this for (what OS also), and what do you have now that you're not replacing?
<< Correct me if I'm wrong, but the only difference between the 1040 and the 840 models from Antec is the locking front-cover and an inch or two more space in the 1040? Seems unnecessary.
you're right, but I couldn't think of the model # of the 840, so I didn't mention it 😱
Right now im running Windows ME, i got a Elsa Geforce 2 32mb GTS. Thats probably all im going to keep. But not sure yet. And that stuff i posted... hows it? And i didnt wanna spend $100 on a case? Are there any good ones for around like $70 and under?
thanks...hehe but no work for me = no money 🙁
well... would all that stuff i listed work together and anyone else have any suggestions?
