Co-worker wants to upgrade a machine at work.
I need a recommendation for an inexpensive MB for an AMD chip.
Basically we still want to use the old RAM (PC100, 128 MB I believe), and there's a
30 GB 5400 RPM hard-drive, probably ATA66, old video card (8 MB?). Basically the machine was a PII-233
and it's getting a lit' slow. Mostly used for web access, word-processing application,
occasional Powerpoint, Photoshop type work to edit images for presentations, etc...
Basically, we just want to upgrade the MB & CPU to speed things along a bit as multiple applications
running at the same time really makes the machine crawl...& we're on
a budget, I figure < $100 for the MB, $100 for the CPU/fan/heatsink combo.
So don't really need DDR RAM, etc... will MB that support DDR support PC100 memory?
