- Mar 8, 2001
- 12
- 0
- 0
I am trying to build a computer from scratch and I need to know which motherboard would be best for me. First of all can someone explain the differences among Slot 1, Slot 2, Socket A, Slot A, Socket 370, Socket 7, 8, 423, etc. What does all this mean?
I was recommended to buy only ASUS products as they are supposed to be the best and most reliable. I would like to build my computer such that it doesn't get outdated very quickly. I was thinking of getting one that would support at least a Pentium 3 running around 1 MHz. I am not sure if I should venture into the Pentium 4 level, as these have not really been tested(?). Also cost is a factor and I do not want to spend more than $250 +/- $50 each on the CPU and motherboard. Also, I wanted a motherboard that will support at least 750 MB to 1000 MB of RAM. The ASUS Motherboards I was considering are: P3V4X, CUV4X-M, CUV4X-E, P4T.
Do you think these are good choices. Can you wizzards out there suggest similar/better ones in my price range?
The other components I want to add in my computer are: 1. PlexWriter? 12/10/32S drive (SCSI); 2. UltraPlex 40X Wide40X Wide SCSI CD-ROM drive; 3. Adaptec SCSI2940UW SCSI card.
I want to use my computer for CD burning, some home video editing, usual home business purposes, and some gaming. Also, in relation to a CD burner is there any advantage to getting a SCSI versus an IDE version? I am told that the burnproof technology of Plextor may eliminate the need for a SCSI interface. Is this true?
Any help you people can offer this novice would be most appreciated.
Thank you.
Thank you.
