I have an Asus KGPE-D16 mobo with two G34 sockets, but only one AMD 6136 2.4 GHz 8-core CPU on there now, with 48 GB memory and GTX 580 graphics. I need more processors for some computational chemistry work. I could add another Magny-Cours CPU of the same type for $780.
http://www.newegg.com/Product/Produc...Tpk=amd%206136
However, Newegg also lists a 12-Core Interlagos CPU with some faster/larger specs for only $480.
http://www.newegg.com/Product/Produc...82E16819113032
I'm a chemist, not a comp sci, so I don't know what the second CPU is lacking, or why it is so much less expensive. The comparison utility on Newegg suggests that it doesn't have hypertransports, an L2 cache, or an integrated memory controller - but that can't be right, can it? It has an L3 cache listed.
Q1: will the 12-core Interlagos CPU do everything that my 8-core Magny-Cours CPU does, only a bit faster?
Q2: can I mix the 2 processors on the same mobo?
Thanks,
Thanks,
