I have a very old computer that I am tring to rebuild out of sentimental value. It only has 2 ide ports, a hdd (40 pin) and a fdd (34 pinn). The computer used to have 2 floppies and a cdrom on the fdd plug, but I took off one of the floppies, making it just the cd and the 3". The cd has 40 pins and the 3" has 34, but they were both run on the same ide cable...34 pin. furhtermore, the 9th through the 16th wires on the cd connection were flipp flopped, but not on the 3". First question: why is it like this? Next problem...the 3" will not boot unless the cdrom is in line above it. When I remove the cd it just says that there is a boot error and to insert bootable media...even though the media will boot with the cd rom in the line, but the cdrom will not be recognised when the drivers are loaded up...even though the cd is plugged in. What is causing this and how can I fix the problen?
