well i had a fop32 and put a delta black lable on it , and was able to get my duron 650 up to 936 at 46 degrees using an the extermal diode that came with the a7v revison 1.01... my sister was complaining that it would keep her up at night so i swapped out the delta and put back the old fan , right now under a full load of rc5 i'm at 52c at 900... this isn't really good , should i upgrade my heat sink to somethinkg from peltec add a peltier to my fop or can i add say a 80mm fan to my fop like you can to the alphas ... if i can does anyone know how to do it
joey
joey
