- Oct 26, 2005
- 987
- 2
- 0
I currently am running a Dell e1705 with the following specs:
T2300 Core Duo (1.66GHz)
2GB DDR2-667
GeForce GO 7800 (non-GTX)
My primary game is Halo PC and my chosen resolution is 1920x1200 to get a 1:1 on my screen and my HDTV (when I play via the home theater). For the most part, getting over 60fps on Halo, BF2, and Source games is easy, even with all the eye-candy, but I still get frequent dips.
Turning off specular lighting or particles in HaloPC results in a pretty nice gain in frames, but then it just doesn't look as nice. I have OC'ed my GPU via hacked nVidia drivers (core: 250-->375, mem: 400-->890) and noticed a nice boost in performance. I'm thinking that its Halo's particle and physics calculations that cause the performance drops.
I bought this laptop because it was an ultra-bargain brand new ($1050) and I knew I could upgrade the CPU and GPU at a later date, albeit a difficult and rather expensive task. So now I'm facing two upgrade paths: a Core 2 Duo (Merom) or a 7900GTX GO. I figure going from the lowest-end CD to the highest-end C2D with remove any CPU limitations, but the T7600 is ~$630. I also believe that the 7900GTX (~$500) would be CPU limited with my E6300. In a perfect world, I would have $1200 to get both items or just buy a whole new laptop, but perhaps there's a middle ground?
Merom pricing is as follows:
C2D T7600 2.33GHz 667MHz 4MB $637
C2D T7400 2.16GHz 667MHz 4MB $423
C2D T7200 2.00GHz 667MHz 4MB $294
C2D 5600 1.83GHz 667MHz 2MB $240
C2D 5500 1.66GHz 667MHz 2MB $209
I know that an upgrade to any one of those will be better than what I've got now, but let's say that I'm not ever going to upgrade my GPU... which CPU would match up best with my 7800 GO?
2GB DDR2-667
