Need Monitor Advice
kl899
ok i think i've narrowed my monitor search down to 2 monitors:
samsung syncmaster 955df: 1600x1200@65hz
.25dp(.20 horizontal)
http://www.samsungmonitor.com/html/955df.html
samsung syncmaster 950p: 1600x1200@75hz
.26dp(.22 horizontal)
http://www.samsungmonitor.com/html/950p.html
unfortunately the 950p isn't perfectly flat like the 955df... not sure by how much though. Both of the monitors cost the same at onvia.com. I would get the 950p but I'm concerned with it's flatness and clearity compared to the 955df. The reason the 955df turns me off is because of it's low refresh rate at 1600x1200. Any suggestions?
I could go for a vs-19sn from kds. It has nearly the same specs on paper but is $30 less. Please help!
