Need Mobo Recommendation for Slot A 800 Mhz T-Bird...please help
Wolverine27
2,350
I've got an 800 Mhz Athlon Thunderbird and I'm looking for a good motherboard that will support it. My main criteria are stability, 5 PCI slots minimum, 3 dimms minimum...
Any help or suggestions is greatly appreciated.
airfoil
1,643
Wolverine27,
Going by all the reviews I've read so far, I'd go with the Abit KT-7 Raid or the ASUS A7V, as recommended by Anandtech! Read the reviews for these boards on the main site or use these:
Abit
Asus
themightyplatypus
557
The kt7-raid is useless to you. The kt7 is a socket a board and you have a slot a cpu. The abit ka7 and ka7100 got very good reviews(both are slot a) and will fit your criteria.
Wolverine27
2,350
themightyplatypus,
Thanks for the rec, but I already have the Abit KA7 which I've tried running my Slot A 800 Mhz Thunderbird on, but it won't run stable. I have a Slot A 750 Mhz Non Thunderbird which runs fine on the KA7 board. However, I need another mobo for my 800 Mhz T-bird...
I've also checked Abit's website and they state that neither of their Slot A mobo's officially support the Slot A Thunderbirds.
Thanks.
themightyplatypus
557
I heard there are serious stability issues with the slot a tbird and ka7. I was more worried about the incorrect info given in the previous reply.
tbird slota + kt7 raid(socketa)= tbird is not gonna fly
Wolverine27
2,350
Appreciate the concern. I've got a Duron 800 running on a KT7 and I love it. However, I need to find a good board for my Slot A T-bird since I don't want to waste it! Anyhow, I found an Asus board on their website, the K7VT, I believe that supports Slot A T-birds. Only problem is I can't find it out in the retail channel.
Someone out there must be running slot A T-birds...please help.
Thanks.
Wolverine27
2,350
Tachyon,
I don't know your e-mail and I can't view your profile. Anyway, what processor were you running on this? Was it a Thunderbird? Any issues? You can PM me or send e-mail.
Thanks.
fox1
24
Wolverine27
The Asus K7V makes a great board for the Slot A T-birds, once you perform the mods on the motherboard. The instructions are on Tom's German site and basically is the addition of 4 SMD caps and a couple of SMD resistors. I did mine and it works great (750 @ 900 mhz). You can probably pick up one of these boards easily because like you stated the K7V-T are impossible to find.
Wolverine27
2,350
Hey Fox1,
Thanks for the info. I'll check out Tom's site and see if I'm up to the task for the modifications. Thanks again.
fox1
24
Wolverine27- Forgot to mention, Tom's German site is in German so you'll need a translator. I wish I still had the link that was given to me by one of our gracious members.
Wolverine27
2,350
Hey Fox1,
I found the translator and I did find the article on Tom's German Site. Thanks a ton! The article actually talks about turning your K7V into a K7VT. Well, I'm off to read it now. Oh yeah...here's the URL for the translator...pretty cool...
Alta Vista Translator
SuperSix
You CANNOT *reliably* run a TBird core SlotA processor on ANY VIA KX133 board.
Get the MSI K7Pro, still availaBLE FOR ~99.00
the board you pick MUST have the AMD 750 "Irongate" chipset.
fox1
24
SuperSix-
Not to flame but what do you base your comment that a Slot A will not run on ANY VIA KX133 chipset on? Dr. Tom is as big a pompous as_ as I've ever met at times, but I will admit he is very knowledgeable and highly respected. So when I read his article on how to modify the Asus K7V to run a T-bird, I believed him. Contrary to what you claim, I can run a Slot A T-bird on a VIA KX133 chipset motherboard reliably, and have for over a three weeks now. It runs 24/7 and I can't remember a single lock-up since turn on, even with my CL DDR Geforce.
doron
54
According to Aopen the AK72 with latest bios does support slot A t-bird
up to 850 Mhz
