Need MoBo for E8500 Wolfdale
thatleftamark
I just tried to put an e8500 in my Asus T3-P5G965 barebones system. The fans run but it never POSTs. I'm assuming that the Wolfdale/E8500 isn't supported by that MoBo... but now I can't return the CPU so I want a recommendation for a MoBo that will support this chip. I'll just end up with a second PC, which is just fine.
Anyone have a recommendation for a good mid-priced MoBo for the 8500?
Thanks!
dbcooper1
594
Don't know about the Shuttle but I'm running an e8500 on an Abit P35-e at 4GHz with current BIOS with no problems.
Nov 26, 2005
15,194
403
same here, running a 8400 on a P35 board, only thing is the P35 will not run memory or RAM at 1N or 1T ... for me anyways..
aatf510
1,811
I am not so sure that DDR2-800 actually runs 1T. At least that's my experience with Nvidia 680i & P45.
The ASUS P5Q Pro should be a good & cheap overclocking board for a E8500.
Anubis
78,712
427
tbqhwy.com
yea im running a E8400 @4ghz on a abit P35E as well, same bios that came with it like 9 months ago
dbcooper1
594
Memory timings are overrated anyway. Top end CPU speed is most important for most applications.
thatleftamark
Maybe a dumb question, but what the heck is 1N or 1T?
Nov 26, 2005
15,194
403
1N & 1T are the same; 1T was the old description for a command rate that you could do with your memory. On an AMD machine, the performance was very noticeable. I think it equated to something like 200 or 300 theoretical Mhz in a performance increase.
JPB
4,064
89
Thanks!
Gigabyte UD3P and never look back.
It has overclocking options through the roof. You wont be disappointed.
OCNewbie
7,596
25
Seconded, and it's on sale now at $99AR! - Link
GullyFoyle
4,362
11
What stepping is your e8500? Don't know about other P35 boards, but newer E0 stepping will not work on Abit IP35 boards. Found this out after getting a new e8400.
Something to watch out for.
KeypoX
3,655
lol i dunno about that. Links?
Nov 26, 2005
15,194
403
lemme guess, you are an intel guy who never has had an AMD machine right?
faxon
2,109
asus p5q-PRO p45 board is a popular choice as well. probably one of the highest selling motherboards on newegg right now to boot, with a ton of good reviews. cant go wrong there, unless the board is DOA
ghost recon88
6,196
Yep, and speaking of which, I have one for sale ;)
Check my sig.
walk2k
157
Another vote for the P5Q Pro. I got mine about 2 months ago on 'Egg for $120. I don't really recommend spending less than $120ish on a motherboard, unless you are going for an extreme-budget build, they usually cut too many corners. P5Q Pro has 100% Japanese caps, passive heat-pipe cooling, has about everything you would need (2x PCIe x16, SATA/RAID, tons of USB and firewire, SPDIF audio, gigabit lan) and is very overclockable.
OCNewbie
7,596
25
There was a combo of the P5Q Pro AND 2 Gigs of OCZ DDR2 memory 2-3 weeks ago for $86. So a specific price point isn't necessarily a deciding factor for a good motherboard.
