Need Mobile Radeon driver help!
Vageetasjn
Got a laptop here with XP installed, but no other original manufacturer discs. It has the IGP 345 video chipset, but I can't find suitable drivers for it. I tried driverheavan's Mobility Modder, but during the catalyst install, it gave an error message.
Error message is "INF error: Video driver not found."
In device manager, there is no Display Adapter so I can't install the driver manually.
Did you try the Omega drivers? IIRC, they are already setup to install for mobile radeons, the readme file should let you know if your particular chip is supported.
Where can one download the OMEGA drivers?
Cause i have the same type of pc and the same problem, but dont know where to get the Omega driver
and what is this mod you're talking about..
Can you put up links to the two places (drivers/mods) please..
Thanks in advance...
