I'm finalizing my core i5-760 build on a Gigabyte P55A-UD3 motherboard and need some help selecting the proper memory. I don't want it to have tall heat spreaders because I will be using the Hyper 212+.
Here are two of the QVL list that I was thinking about, both from Gskill....
F3-12800CL9D-4GBNQ
F3-10666CL8D-4GBHK
They are both the same price on newegg ($92), but one is 1333 and other is 1600. I'm a little concerned about high the reported high RMA rates on these from user reviews at newegg.
Any advice?
I have a Frys nearby that I can easily pick up some ram from....
Thanks for the help.
F3-12800CL9D-4GBNQ
F3-10666CL8D-4GBHK
Any advice?
