Guys,
Not sure if this is the correct section but I'll give it a shot. I'm looking for numeric sequence prediction program. Say if I input a set of # or #s say three times and see if it can find a pattern on the next #.
say if I input
first input 3 0 0 4 2 9 6
second input 4 1 1 5 3 0 7
third input 5 2 2 6 4 1 8
Now if you're looking at the above # you would notice that I add one to each # every round. I need a program that can find patterns like that and predict the next #. Basically a program that can think and uses a gizillion methods to see if there is a trend/pattern and try to come up with the next set of #s. Is there such program and can I acquire it for use.
Or a second example would be something like this:
First set will be a+b+c = D
second set (D+a)+(D+b)+(D+c) = D
third set will be the same as second set because it just repeats the same process so
a,b,c would be what I would inpute and D would total +a,b,c and so on.
Is there such program? Also if i'm not clear on anything please let me know.
say if I input
