Originally posted by: Googer
Using normal -7DB splitters causes too much signal loss. What I need is a [google]low loss, high bandwidth COAX cable splitter[/google].
Originally posted by: Nohr
I've been using this splitter for TV & cable internet. -4db on each leg.
Originally posted by: krotchy
How many directions are you splitting?
Each split has a fundamental loss of -3.5dB, since that corresponds to slightly less than half power.
If you split 2 ways, you can get a -3.5dB splitter for both legs
If you split 3 ways, you can get a -3.5dB.-7dB.-7B splitter or a -4.5dB,-4.5dB,-4.5dB splitter.
For a nice full bandwidth 2 way splitter, monoprice works. If you want an amplified splitter to get little-no signal loss, check partsexpress but they can be expensive.
Heres the RF amps:http://www.partsexpress.com/we...bjectGroup_ID=529&SO=2
Exactly. There is no getting around this.
However, with the advent of digital broadcast signals...signal amplifiers now make much more sense.
Amplification.
Originally posted by: The Boston Dangler
an all-passive system would be best if the levels are within spec. what is the application?
Amplification.
uh.....yes?
I agree, all passive is the best way to go. I have a short and medium range outdoor antenna that was originally used for FM radio, I am splitting the signal two ways: One goes to the radio and one goes to my Sony (ATSC) KD-34XBR960. However, spiting the coax gives me no signal on either device. I have dozens of various splitters lying around, most have different specs of loss and bandwidth (don't use splitter with bandwidth higher than or out of the range that you need).
