bob4432
as the summer comes closer and closer my computer room gets warmer and warmer. i am getting rid of 1 machine and re-doing one home server which is currently a xp2000 w/ 1GB of pc3200 ram, 1xide hdd, 1x sata hdd, 1x120mm, 1x80mm fan, a 350W antec psu and a fanless agp gpu.
my goal is to get a bit more power in terms of cpu but to lower the overall power usage and heat output with minimal amount of $$$ output.
what i will be keeping from the current build -
1GB pc3200
1xide hdd
1xsata hdd
1x120mm fan
1x80mm fan
i know i could pick up a 35-45W skt A cpu, but the prices of those are more than 939s, and have less than 1/2 the performance, plus no throttling.
so, are there any good m/bs that support ddr1 and a am2 (one of their low power d/c units would be excellent 🙂, one mixed with onboard GbE, video, sata (no raid is necessary) would be a greatly added bonus. cost is a huge factor as i already have the cpu power i need for what the machine does, but it pours a lot of heat out of it.
i am also looking at picking up a decent priced, efficient psu, something in the 300-400W range that is 80%+ certified, probably a enhance, etc.
thanks in advance for your time.
also, this is a 24/7 rig - will be running probably xp pro and does duty as a print server, image storage of all the othe machines hdds, http and https server, ftp and ftp-ssl server but most of the time it is using very little power, so the ability to be able to throttle down would be nice.
some of you may say to just cut the V and fsb on the current setup - tried it, this is a weird setup and whenever i move the fsp either up and down, no boot, so that is out of the question.
1GB pc3200
1xide hdd
1xsata hdd
1x120mm fan
1x80mm fan
