Ok, so I borrowed my friends laptop to use this summer in europe. Its a Compaq Pesario 700, winxp sp2, nothing special, but I just need it for email, irc and the web so it will get the job done. I fired it up before I left and installed a few programs I would need, everything worked fine. *Flight from Atlanta to Amsterdam and three days in Amsterdam (computer not turned on at all)* I get here to France and boot it on up from the battery. Everything is fine, I mees around for a bit with stuff and no problems at all. I plug in the network cable (doesn't do any good, we didn't have the internet set up yet) and in a few seconds the laptop says its going into hibernate mode and then it goes black. I wait a minute or two and try to turn it back on and the battery light just flashes at me. The guy I borrowed it from said the battery is bad and wouldn't last long, so no problem. I go to the local version of wal-mart (its called Cora and its just like wal-mart without all the whitetrash) and get a plug adapter (not a convertor, the little black box in the middle of the power cable handles the EU v. US power difference). I connect it all and let it charge for awhile. Hit the power button and nothing. When its connected to the wall the power plug light comes on, so its getting power, and when I first plug it in the battery light stays on for a bit and then goes off (after 10 minutes or so). One final note: I noticed that I failed to remove the wireless card from the side of the machine when I packed it and its now jammed in there farther than it should be, I know thats a problem, but it worked with it like that when I first got here so I don't see why it wouldn't do it again. Any and all help is greatly appreciated. Thanks in advance.
Bux
Bux
