Need jQuery master ... Need previous and next buttons for my slider. Help
dalearyous
i don't know jQuery at all really but i need to link a previous and next button for a slider with the following code. (this code already works but clicking numbers associated with the slide but i want next and previous buttons as well).
Code:
<script type="text/javascript">
//Show the paging and activate its first link
$(".paging").show();
$(".paging a:first").addClass("active");
//Get size of the image, how many images there are, then determin the size of the image reel.
var imageWidth = $(".window").width();
var imageSum = $(".image_reel img").size();
var imageReelWidth = imageWidth * imageSum;
//Adjust the image reel to its new size
$(".image_reel").css({'width' : imageReelWidth});
$(document).ready(function() {
	//Paging  and Slider Function
rotate = function(){
    var triggerID = $active.attr("rel") - 1; //Get number of times to slide
    var image_reelPosition = triggerID * imageWidth; //Determines the distance the image reel needs to slide
    $(".paging a").removeClass('active'); //Remove all active class
    $active.addClass('active'); //Add active class (the $active is declared in the rotateSwitch function)
    //Slider Animation
    $(".image_reel").animate({
        left: -image_reelPosition
    }, 500 );
//Rotation  and Timing Event
rotateSwitch = function(){
    play = setInterval(function(){ //Set timer
        $active = $('.paging a.active').next(); //Move to the next paging
        if ( $active.length === 0) { //If paging reaches the end...
            $active = $('.paging a:first'); //go back to first
        rotate(); //Trigger the paging and slider function
    }, 9990000); //Timer speed in milliseconds
rotateSwitch(); //Run function on launch
//On Hover
$(".image_reel a").hover(function() {
    clearInterval(play); //Stop the rotation
}, function() {
    rotateSwitch(); //Resume rotation timer
//On Click
$(".paging a").click(function() {
    $active = $(this); //Activate the clicked paging
    //Reset Timer
    rotate(); //Trigger rotation immediately
    rotateSwitch(); // Resume rotation timer
    return false; //Prevent browser jump to link anchor
$("a#next").click(function(){
rotateSwitch();
nevermind:
Code:
<script>
    //Slider Animation
    }, 500 );
//On Hover
}, function() {
//On Click
    //Reset Timer
//Handles the left and right arrows
$(".right_arrow a").click(function() {
if ( $active.length === 0) { //If paging reaches the end…
$(".left_arrow a").click(function() {
$active = $('.paging a.active').prev();
</script>
