need java help! auuuuuuuuuuuugh!
ss59
Banned
i can't find javax classes int he linux sdk from sun, or anything else for that matter. what gives? i need to use javax.swing for my program!
Can you be more specific by what you mean by saying "you can't find" the javax packages? They're all there in the SDK.
that's what i'm saying. the javax package that came with the sdk i got has nothing. there are some .java files, but no swing directory, or the likes.
<< that's what i'm saying. the javax package that came with the sdk i got has nothing. there are some .java files, but no swing directory, or the likes. >>
There aren't any .java files nor any swing directories to look at. They're all stored in .jar files as .class files. Have you tried writing an app by importing the packages?
there are no .jar files in there. when i try and compile it gives an error saying can't find javax.swing strangly enough there are alot of .h files for some reason
