Im trying to configure my first shuttle (making the switch from full towers) so my comp can be more mobile. With the holidays coming I will have lots o $$$ 😀. The main problem is choosing which model to build (SN25P or SN26P).
Most likely I will not have SLI in a shuttle because I think that is suicide. I would also like to have 2 harddrives in it (looks like the SN26P cant utilize that?). The rig will be used for gaming mostly, video editing/graphics design as well.
Here are the specs I would like: Please confirm them (if they will work/fit within case restraints and ps issues)
AMD 4000+ (http://www.newegg.com/Product/Product.asp?Item=N82E16819103529)
2GB OCZ Ram (http://www.newegg.com/Product/Product.asp?Item=N82E16820227210)
74GB WD Raptor HD (http://www.newegg.com/Product/Product.asp?Item=N82E16822144160)
500GB HD (not sure which company yet, probably hitachi)
7800 GTX (This is where I am most concerned, if I get a 512 version some people say it wont fit in the SN25P but the SN26P is such a huge premium for 1 extra video card slot :|, im also concerned with the heat problems for SLI upwards of 75 degrees?)
Also are there any "newer" 939 shuttle models coming out that I should wait maybe a couple of months for?
