Need input on wireless bridge situation
The situation:
Linksys E3000 hooked up to cable modem in living room (stock firmware)
PS3 & Xbox hooked direct to Linksys
Adding Xbox in office (~15 feet line of sight from router, through a couple walls)
Want to bring USB-only printer in office onto the network
The complication: will be adding a wireless headset setup that uses 2.4GHZ and doesn't respond well to interference. Need to have all devices in office on 5GHz band. Xbox has built-in WiFi, but it is 2.4GHz only.
The solution?
Solution A: Use 4-port dual-band wireless bridge. These are expensive ($70+) and I still have to buy a USB-Ethernet print server (~$15-20).
Solution B: Use 1-port dual-band wireless bridge (~$40) and plug cheap switch into it (~$10-15). Still have to buy USB-Ethernet print server.
Solution C: Buy 4-port dual-band wireless router that supports DD-WRT and use it in bridge mode. This ONLY makes sense if I can get one that has a USB port (~$70) that will support my old Samsung SCX-4100 and IF that will still work if the router is in Bridge mode. This is an attractive option to me, esp since it's one box, but I have no idea if the USB print support will still work if it's in Bridge mode.
What does ye olde peanut gallery think? Thanks in advance folks
