need input on hot chipset,artic siver and heat sink
lapdog
248
overclocked cpu now chip set is to hot for liking.is it possible to put a blue orb on the kt7a raid main board? or should i just go with artic silver, and what are the main diffrences in the 3 brands artic siver and what one to use on cpu and and heat sink of chip set? should you sand the heat sinks?
tia
Felonious
94
Artic Silver Thermal Paste is for thermal conductivity
Artic Silver Thermal Epoxy is an adhesive that promotes thermal conductivity
The Epoxy comes in 2 parts (to be mixed)
You can add 1 part Thermal paste to the Epoxy mixture to weaken the bond a little in the event that you would choose to remove (said fan or ram sink etc..) at a later date.
I used the triple mix to attach my Blue Orb but there is guide to do it otherwise here
If you want to sand (lap) your heat sink, you can get wetdry sandpaper from an auto parts store for about 50 cents a sheet. I used 600 grade, 1000 grade and 1500 grade to make it shiny.
The copper spacer I used was the DTS400 from www.cpufx.com because it is finely machined and has cutouts for the feet and bridges.
My Tbird still runs kinda' hot anyway, but my northbridge is chillin'
