Need info on Reverse Osmosis Water System
I recommend the EcoWater ECO-550 reverse osmosis system. It is a 5-stage system that is rated for 50 gallons per day. You won't use 50 gallons per day, but it won't REALLY produce that much either, since they are rated for ideal conditions. The 5 stage design really does a good job on the water... each filter takes a certain percentage of contaminants out of the water (90 -95%) so the more filters the better. You want one sediment filter and the rest carbon. You should have to change them once per year, except for the first pre-filter.
Do you want one that you hook up to your whole house, put below your sink or do you want something above counter that you can hook up to your faucet when you need water.
Shaklee Corporation makes some good R.O. systems, I'm actuatly drinking water that's been R.O.ed through a whole house filter and then run through a counter-top R.O. system. Gotta love pure water.
You have to watch out, you get spoiled by R.O. and drinking anything else sucks.
