EXCellR8
Hello, I've been looking for a definitive answer to a problem I am facing with configuring RAID on my machine. I basically need to know if it is possible to have two drives (in this case 80GB Intel SSDs) set to use RAID and, simultaneously, use a few SATA drives that are NOT using RAID? I've been told that this is both possible and impossible so I haven't been able to draw any conclusions.
I want to use RAID 0 on the SSDs to install my OS but then keep the file structure of my other disks the way they are. My understanding is if I change the setting in BIOS "configure SATA as [RAID]" will cause my disks to become corrupt? Right now they are set to "IDE" because I am not using RAID. My motherboard is the ASUS P6T (base model?) not the SE or Deluxe with the ICH10R south bridge; I am using Win7 64-bit.
Any help would be greatly appreciated, thank you!
