need info on low profile bracket
gameworm
Recently bought a Leadtek Winfast PX6200TC Low Profile for my Dell 5100PC. The card doesn't come with a low profile bracket. Is anybody using this card with a low profile bracket? Where can I buy one? I searched on Google, it seems there are only serveral brackets made for some special models like Powercolor X300 etc.
The card works perfectly for me, just want to install a bracket to secure the card. So don't want to put too much money on it. Tried local Frys and Microcenter, no luck.
thanks for any input.
jk
Normally they're made for a specific model, but you might be able to find one that would fit. Directron has a couple; not sure if one of those matches the port layout of your card.
If you needed a card with a half-height bracket (rather than just the card being low-profile), you really should have bought one that comes with it. As you've noticed, it can be hard to find one that is an exact fit.
