Need info on Liquid Cooling
Str33tR4C3R
I'm planning on building a computer this comming spring. I know that's quite a while away but I want to get the research out of the way. I would appreciate it if people respond who either are already planning on installing this or who have already done so.
  1. First of all, how much does it cost to install a GOOD liquid cooling system?
    Is it silent?
    Can you use liquid cooling for DUEL processors (AMD)?
thanks in advance.
Str33tR4C3R
<< Don't know about building your own water cooling system, but Koolance has a pre-made system that has gotten a few good reviews here and here. >>
I'm not building a water cooling system....I'm building a system which utilizes water cooling.
AFSOC_Commando
1,518
I would recommend you go to http://www.overclockers.com and look in the watercooling section there. They hav one of the best article choices on all types of PC mods... I used them for a ref when I put my watercooling together
Now as to your questions... My system is quiet until I flip on the fan... I have a 120mm pushing 70CFM and it does make some noise...
Yes you can water cool a duallie... you can water cool a vid card, mobo chipset and more...
Take a look at the link above and spend a few hours reading all the revies and articles and then you should have a much better idea how it can be done
