Need info on Dell 1702FP 17" 1280x1024 TFT LCD...
GetInMyFatBelly
1,128
Does anyone know of the Manufacterer of these Dell TFT's? I would like to find the rise and fall Response time (ms) specs.
Anyone have one of these? Are they a good monitor?
Here are the specs listed:
Screen type: Active matrix - TFT LCD
Screen dimensions: 17 inches (17-inch viewable image size)
Pixel pitch: 0.264 mm
Highest addressable resolution: 1600 x 1200 at 60 Hz (UXGA)
Luminance output: 200 CD/m² typical, 170 CD/m² minimum
Contrast ratio: 350 to 1 typical, 250 to 1 minimum
Faceplate coating: Antiglare with hard-coating 3H
Backlight: CCFT (4) edgelight system
Panel: DC input 14 VDC at 3V
Connector type: 15-pin D-subminiature, blue connector; DVI-D, white connector
Height: 458.5 mm (18.1 inches)
Width: 440 mm (17.3 inches)
Depth: 220 mm (8.7 inches)
Manufactured by: Dell
Manufacturer Part No: 8G152
