- Feb 22, 2007
- 16,240
- 7
- 76
For about 2 weeks I have had terrible packet loss with my cable modem
Uploads are about the 8KB range, when normal is 1024KB.
Downloads sometimes reach 10mbit, which makes me wonder why the upload is so poor.
They have done the signal test, all thats fine.
The thing is they keep sending out low level techs who look at the modem signal strengths and say thats fine, nothing else they can do. They also might do a trace route and find no packet loss or one drop.
Problem is they are using the standard windows trace route.
If I use a trace route and increase the packet size to 512bytes thats when the connection goes all to crap, averaging 20-50% loss on the first hop. The techs don't seem to care about that, as they don't seem to understand packet size.
I ran a packet capture program to see whats going on with my connection and when I pull up web sites I have to hit refresh a few times then it may or may not load.
What I see in the capture is things like :
Maybe if I can figure out why its happening I can get it through to someone at the cable company and get it fixed.
What I want to know is what kind of conditions on a router like the cable company is using would cause the above problems and why would they only show up with larger packet size ?10888 2942.895031 192.168.1.197 208.65.201.104 HTTP [TCP Retransmission] GET /www/delivery/ajs.php?zoneid=9&cb=51232671511&loc=http%3A//forums.anandtech.com/categories.aspx%3Fcatid%3D37&referer=http%3A//forums.anandtech.com/messageview.aspx%3Fcatid%3D37%26threadid%3D2100352%26enterthread%3Dy&context=YTowOnt9&mmm_fo=1 HTTP/1.1
10875 2936.205911 204.11.109.64 192.168.1.197 TCP [TCP Dup ACK 10874#1] http > 1819 [ACK] Seq=725 Ack=983 Win=49640 Len=0
10847 2935.747620 192.168.1.197 64.86.71.24 TCP [TCP Retransmission] [TCP segment of a reassembled PDU]
