- Dec 29, 2005
- 89
- 0
- 0
every student at my school can get free copies of xp pro 32bit, xp pro 64 bit. you just have to give a lab assistant a blank cdrom and they will give you a copy. i have a working copy of xp pro 32 bit. i want to install 64 bit. the disk they gave me for 64 bit is not bootable.
i just tried an old boot floppy disk that i had with cdrom support (i figured it would boot up fine and then i could run setup from the cdrom drive, but it failed to load the cdrom) but that's not working.
i tried a boot floppy with cdrom support that i downloaded, it did not work. i'm trying right now to use the xp pro setup disks (from a MS utility, makes 6 floppies), but the two times i have tried it, i get errors on different disks, so i am formatting and trying again.
i also tried to download an image that i could boot from my usb drive, but that did not work (nothing showed up on my flash drive).
i can get another copy of xp 64, but that will probably take a few weeks (is summer right now and lab assistants are not at school). is there any way i can start the 32bit setup from boot and then switch it to 64 (switch disks)? or can i update to 64 bit from 32 bit?
any ideas here guys? (and i won't consider go f myself as an idea
thanks
thanks
