Hello.
I'm helping a friend from out of state put his first pc together. He just bought an Antec Performance Plus PLUS660AMG case and I need the IDE and floppy cable lenghts for this case. Just to let you know, the case is 17" tall, has 3 full size drive bays and 2 3.5" bays and he plans on going with the Asus A7N8X mobo.
Here's how he's going to have it laid out..
1 hard drive in the internal removable hard drive location (obviously).
1 IDE Zip drive in one of the 3.5" openings
1 floppy drive in the other 3.5" opening
1 dvd rom drive in the top 5.25" opening
1 cd burner in the middle 5.25" opening
Nothing in the bottom 5.25" opening
No RAID or ATA controller card, so he's going to be utilizing both IDE channels with dual cables.
I need to know what length floppy IDE cable to get. What lenght dual IDE cables to get for the two optical drives and the zip and hard drive. My guess is to put the hard drive on as a master on the primary and then put the IDE ZIP drive on as a slave on the same channel. Then, he would need another dual IDE cable for the two optical drives that are in the top two full size 5.25" drive bays.
I don't have this case, so I don't know what to tell him. If anyone has a similar set up, please let me know what size cables you used.
TIA.
Sal
TIA.
Sal
