need help
h3nG
212
my friend says there's trojans, but my avg scanner isn't detecting it. i tried scanning through a few online scanners and my computer is still clean. but i want to make sure.
please don't click on the link unless you are confident of your virus scanner.
hXXp://www.msndeletechecker8(DOT)tk/
i just need someone to verify.
Thanks!
Hyperlink edited so it isn't clickable. Remember not to post clickable links if you suspect malware.
AnandTech Moderator
mechBgon
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
using Safari on OS X, nothing attempted to download itself to my system which I have noticed happening before on some sites. This however is not a conclusive test.
mechBgon
Oct 31, 1999
30,699
I'll check it out. Remember not to post clickable links when you think there could be malware in them.
