Need help
Czar
Not sure if this is supposed to be here
I have this program that has 3 open windows, only one of them can be seen on the task bar, the others fallow the first one. The thing is that somehow the two windows that you cant see on the task bar are well hidden, they are somwhere on the desktop but not visable, as in out of bounds or something. Do you know any way on to move them on to the desktop?
nuttervm
1,818
make your resolution huge (like as big as your monitor/adapter will go) and drag the other 2 windows over to where the one you can see is. then set resolution back to normal. you will have to squint a little, but i think it should work for an out of bounds type thing:)
