Need Help
arvindrao
Greetings,
Following is the configuration suggested to me by a hardware dealer:
Core 2 quad 2.66 GHZ Processor -
Intel dg45 chipset motherboard -
Kingston hyperx 2gb ddr2 ram (1gbx2) -
Seagate 80gb sata hdd (for os)
Seagate 1TB sata hdd (for data and games)
Sony 22x dvd writer -
Samsung myst 22" lcd with glossy finish and 2ms response time -
Cabinet with 600w power supply
My requirement was:
1) A high-end machine apt for hardcore gaming.
[My query: is this configuration mentioned above good enough?]
Secondly: My confusion
1) What graphic card should i buy?
He suggested: zotac gtx250 with 512mb [But i'm not too convinced.]
What I need:
1) Suggestions/reviews on the hardware that I specified.
2) Suggestions for the best graphics card that I can get.
[I'm looking to invest a decent amount of cash in the graphics card as i won't upgrade for quite sometime after this]
Eagerly awaiting your replies.
Thanks!
arvindrao
I appreciate the prompt response, I'm fairly poor in hardware knowledge, i'll be running this with my hardware dealer. So in case if you are suggesting me a card/something, please mention the full model name...
Cheers
error8
3,204
You have to state your budget, or we'll just recommend you gtx 295, the fastest out there and you're set to game. ;)
arvindrao
Thank you for your replies folks,
Can you please suggest me a card in the GTX range? I was told thats the best and the latest range. [Considering the fact that I'm form india, the latest hardwares aren't available yet] [GTX 280, isn't available, whereas GeForce GTX 260 is, is 'GTX 260' or 'GTX 270' a good card?
AstroManLuca
15,628
Processor looks good (FYI, that would be a Q9400)
Definitely get more RAM. 2x2GB of DDR2-800. No need to spend more for 1066 or 1333. And probably not much reason to get expensive or premium RAM either. Just get the cheapest 1.8V RAM available.
I think one of the better motherboards for Intel is the Gigabyte GA-EP45-UD3P.
Absolutely no reason to get a tiny, old, slow hard drive as a boot drive. For your boot disk I'd recommend a 640 GB Western Digital Black. For extra storage, if you need it, you could get a second 640 GB drive, or a 500 GB, or maybe a 1 TB if you need it. Anything you want, really.
No reason to get a Sony burner unless it costs the same as a Pioneer or LG burner. I don't know if it does, I just know Sony tends to overcharge a bit. Most DVD burners are $20-$30.
For a monitor, if you can afford to spend a little more money, the Dell 2209WA is a great screen. Better viewing angles and less gradient. You could also look at 21.5" LCDs with 1920x1080 (1080p) resolution, which are also quite cheap.
Power supplies are one of the most overlooked components. What brand is it? A 600W Powmax or Rosewill is going to suck, but a 600W PC Power & Cooling, OCZ, or Corsair would probably be pretty good. Those are just a few examples... there are lots of good PSU brands and even more really bad ones that you should avoid.
As for graphics... it depends. Money no object? GTX 295. If you don't want to spend $500+ on a GPU, though, you'll be fine with a GTX 260, GTX 275, or Radeon 4870/4890 1GB. nVidia GPUs above the upcoming GTX 275 are very overpriced and you're better off with a Radeon 4850X2 2GB at around $300. Remember too that you can add a second graphics card later, depending on the motherboard (make sure you get an SLI-compatible motherboard if you go nVidia or a CrossFire-compatible one if you go ATI... many are compatible with both however).
BTW, there is no "GTX 250." There's a GTS 250, which is not too shabby but isn't very high end, and a GTX 260, which is a solid performer at just under $200.
Rick James
386
Nvidia is overpriced and slower then the 48xx series. Reason why i suggested it.
arvindrao
Astro,
I sincerely thank you for your in detail explanation, it has definitely helped me [a complete layman] make my decision...
However, is it possible for you to kinda break it down further,
From what I gather from your reply is, that I should go for either on of the below graphics card:
1) GTX 260
2) GTX 275
3) Radeon 4870/4890 1GB
[I belong to India, $300 [roughly INR 15,000] is a fair enough deal for me, i'm willing to spend upto INR 20,000 which is about $400]
So I finally need the following:
1) Your best recommendation of the above cards.
2) If possible the exact model number [i.e. the full form]
3) Your view on, whether this will be a good upgrade for the next about 3 odd years atleast.
lasoski311
44
like error8 said above, we need to know your budget otherwise we are going to suggested cards in the $500-600 range, and i assume ur not looking for something like that, but because im bored i will suggest a few that in different prices ranges....
$125-150
GTS 250 512MB: http://www.newegg.com/Product/...x?Item=N82E16814130468
$150-175
GTS 250 1GB OC: http://www.newegg.com/Product/...x?Item=N82E16814130470
HD 4850 1GB: http://www.newegg.com/Product/...x?Item=N82E16814161245
$175-200
GTX 260 216 OC: http://www.newegg.com/Product/...x?Item=N82E16814127409
HD 4870 1GB: http://www.newegg.com/Product/...x?Item=N82E16814102801
$200-250
HD 4890 1GB: http://www.newegg.com/Product/...x?Item=N82E16814102830
$250-$300
GTX 280 1GB: http://www.newegg.com/Product/...x?Item=N82E16814143141
HD 4850X2 2GB: http://www.newegg.com/Product/...x?Item=N82E16814102809
$300-350
GTX 285 1GB: http://www.newegg.com/Product/...x?Item=N82E16814143170
$350+
GTX 295 1792MB: http://www.newegg.com/Product/...x?Item=N82E16814130473
HD 4870X2 2GB: http://www.newegg.com/Product/...x?Item=N82E16814102768
error8
3,204
I don't think newegg is a solution for someone who lives in India!!!!
error8
3,204
Originally posted by: lasoski311
thats a good point....i dont really nowhere to look for india though
Nobody does. :laugh:
And you can't even make an idea about what he could get with 400$. In US you can buy the best card possible, in India, that might not be enough even for a GTX260. This is probably why, OP is requesting the exact model when he wants a recommendation.
error8
3,204
I'd say you need to buy one of the following: 4870 1gb/gtx 260 C216 ( with 216 shaders ). Both of them are at the same price and performance level, great cards for 1920X1200 and lower. If those 400$ are enough, you can also get 4890/GTX 275, with a slight performance plus. Again these cards are equal and I'd get the cheapest out of them, although I think there is still some time until you find them available in India. Everything above these, doesn't probably fit in those 400$ you have.
error8
3,204
Astro,
Manufacturer of the card is not that important, IMO. You can look for what card has the best warranty, if that's important to you. Other then that, I would get which one is cheaper, out of those pairs.
zagood
4,102
Good advice all around, except from your hardware dealer. The GTS250 512mb isn't a good choice.
Assuming that the monitor resolution is 1680x1050 (not familiar with that model), you probably don't need anything more powerful than the 4890, but if you can afford it, a better card will allow you more eye candy for games with higher requirements.
Without a specific model# it's hard to tell, but that motherboard probably won't be very good for overclocking if that's your intention. If not, don't worry about it.
Be careful with the power supply. 600w is a good number, but if it's a low quality brand it won't matter.
arvindrao
Ok, this is my final config which i'll be submitting my hardware dealer:
PROCESSOR:
MOTHERBOARD:
RAM:
2x2GB of DDR2-800
HDD:
1TB GB Western Digital Black
DVD WRITER:
Sony 22x dvd writer
MONITOR:
Or
Dell 2209WA
GRAPHICS CARD: [Whichever is in the $400[INR 20,000] mark]
Radeon 4870
[Can please someone help me out with its full form / exact model number.]
Or
Radeon 4890 1GB
[Can someone help me out with its full form / exact model number.]
Or
NVIDIA GeForce GTX 260 216SP XNE/TX260+T394 896MB GDDR3 Sonic Edition Graphics Card
Or
NVIDIA GeForce GTX 275 ZT-275E3KB-FSP 896MB GDDR3 Graphics Card
CABINET:
MOUSE:
Razer gaming mouse with Razer mouse pad
Or
Logitech MX510
Or
Any standard good mouse
KEYBOARD:
Logitech Keyboard
Phew... okay, your final comments please, post which i'll shoot this in an email to my dealer.
palladium
538
He mentioned 'cabinet with 600W PSU', so it's probably gonna be one of those cases with built in PSUs.
To OP: Unless your case/PSU is an Antec brand, I would get a case w/o PSU and a seperate quality PSU like Astro suggested.
