need help
Ok, so my mother's laptop had crashed and upon reboot it says: windows.system32.config.system file is either corrupt or missing. So, I did a test on the drive through the bios and it passed. I also hooked it up to my desktop and everything was intact - ran a Windows defender scan on it and it passed. Still same error. Tried to reinstall but XP says it cannot find disk. I've loaded up bios defaults 3 times. Just got done reformatting it and tried a fresh XP install and it says it cannot find any disk.
Any suggestions???
Thanx
how new is the laptop? Maybe you need to manually load the proper SATA driver during XP install? If the laptop drive is SATA, this is most likely the case. XP sucks with installations with newer SATA drives and controllers.
What version of XP do you have? Does it include SP2 or SP3? Those revisions included much better SATA support than the older original or SP1 packages. Might look into slipstreaming in SP3 if you haven't already.
