Need Help
Advait
Hi Gurus,
We had integrated a system with Intel DX79SI, Intel 3960X, 4x8GB RAM, Asus HD7970 DC2T-3GD5 GPU, Adaptec 6405 RAID Controller, 4 SAS Drives, DVD RW, 1000W Cooler Master PSU etc. On Powering up the system, the POST screen along with system details RAID config etc and freezes with 0_ post error on screen. The On board Diagnostic LED show 00. But system does not boot to OS. The display shows 0_ on right bottom. The same graphic card and other components are functional with other motherboards. The BIOS Ver. is 553.
Kindly advice and help to find a solution.
Thanks in advance.
Hi Gurus,
Thanks in advance.
Hello and welcome 🙂
What does the 00 led icon indicate on the motherboard manual?
Also i would suggest taking out the raid config and testing the machine with a sata drive to see if that works then you will know if there is a problem with your raid config.
