Need help
Xylitol
6,617
You want to use a radioactive tracer that will label only the protein in an RNA virus. Assume the virus is composed of only a protein coat and an RNA core. Which of the following would you use? Be sure to explain your answer.
a. Radioactive P
b. Radioactive N
c. Radioactive S
d. Radioactive C
I have no idea.
proteins are amino acids which are made up of C and N
rna is nucleotides made up of P, N, C
I mean if it was asking for me to identify only the RNA, I would say radioactive P, but that's not the case...
Anyone know?
Dec 10, 2005
28,967
14,291
If you know the coat contains cysteine or methionine, you could use S.
If you want to identify both, it depends on how the material is introduced as carbon can do different things based on how it enters the cell.
N would be useful in that it is found in both RNA and amino acids. It might be the best one to use. For purines and pyridimines (within the primary ring, not the A/G/T/U substructure), the N comes from glutamine (which can easily be synthesized from glutamate and glutamate is the product after amino acids are broken down upon entry through the exchange process with keto-acids) And that glutamate or the .
Xylitol
6,617
N would be useful in that it is found in both RNA and amino acids. It might be the best one to use. For purines and pyridimines, the N comes from glutamine (which can easily be synthesized from glutamate and glutamate is the product after amino acids are broken down upon entry through the exchange process with keto-acids).
But if I'm only trying to identify the protein and since this is a multiple choice question, then S would probably be my best bet right (since all the other things are either common in both protein/RNA or only in RNA)
Dec 10, 2005
28,967
14,291
Yeah - if you're only trying to find the protein coat, I would say tagging S would be the best bet, but that's assuming the coat uses cys or met. All the other elements are not found in proteins or are found in both RNA and proteins. If you wanted to find both, N is the best bet.
Ticky
436
Yeah, I'd say S. I think you're supposed to assume the protein coat contains sulfur-containing amino acids, and the RNA has no sulfur.
summit
2,097
no you would use radioactive p. radio active p would tag the entire nucleotide. by elimination you could determine the protein area if i remember correctly.
Ticky
436
But you want to tag the protein... not the RNA. What's wrong with tagging the S?
Dec 10, 2005
28,967
14,291
If the OP worded the question properly:
Labeling by elimination is not an option, as the question states "label only the protein."
summit
2,097
well label means identify imo. you might not be able to use S since you dont know the protein coat?
SirStev0
10,449
This is actually based on the way they determined what the code carrying components of cells were (before they had fancy electron microscopes and all the other gadgets.)
It is called the Hershey-Chase Experiment
There are never Sulfurs in nucleotides but there are a two amino acids that have sulfurs and there are rarely phosphates on proteins but there are tons associated DNA and RNA. They labeled cells and saw what was being transferred. Could see it was the Radioactive phosphate and figured out that Nucleotides moved and carried genetic codes.
summit
2,097
2 years out of the loop. :beer:
Dec 10, 2005
28,967
14,291
But if you label the RNA with the radioactive P, you won't be able to see anything as the whole cell-virus factory will light up. It won't show you where the virus protein coat is.
SirStev0
10,449
huh?
Dec 10, 2005
28,967
14,291
huh?
I assume it's 2 years since an intro biochemistry class.
It's only been a few months for me, but cellular biochemistry isn't really my strong point. I'm a bigger fan of the chemistry of proteins (and synthetically making them in the lab).
SirStev0
10,449
huh?
ohh..
Btw OP? what type of class is this for. If it is an intro-ish class and one of first few days, I would think that you are almost over thinking it. I am sure the main point they want to make is that both have carbon and nitrogen, but one can contain sulfur and the other can contain phosphorus (in the form of phosphates).
