NEED HELP!!!!!!!!!!!!!!!!!!!
Detox108
I tried installing some new bios on my brand new PC, and now it won't boot up. The fans start up and then stops, and it just keeps doing that.
I checked the manual, checked the site, checked everything. I tried resetting the motherboard, re-plugging and plugging the PSU, everything. And nothing works. I believe the bios are corrupted.
My setup is a Core 2 Duo E6400, Gigabyte GA-965P-DS3.
Any ideas.
did you remove the CMOS battery and tried the BIOS reset?
just a hint/guess on other things to try.
Yes I believe the BIOS is corrupted too. This is a bad thing.
Unless you have access to another board of the exact same type, you will have to take it to a shop, or get a new chip.
