Need help
thebruiser
101
I hope this is the right forum. I had to replace the hard drive in my mp. I reinstalled all of the software that came with, and upgraded to SP2 so the larger hard drive would be recognized. The pc came with some video programs, including PowerVCR, PowerDirector, and a couple other things. I also reinstalled Nero 6, and updated it. The problem is the video capture programs no longer work. A pop up msg says "video capture device is not detected". The video capture is built into the pc. It has connections on the front and rear. The video card is a GEForce4 Ti4200 with 128 megs. Not the best, but it works for what I do. I went to nvidia's site and upgraded the graphics driver. That didn't work. I then started downloading the wmd drivers that were there. Another pop up appeared that said something like "installing this software will cause harm or cause your system to become unstable". What do I do? I suspect I need drivers. The capture program worked before the hard drive failed. Will those drivers actually cause problems? I don't see a manufacturer's name on the card. Will someone help?
the cobbler
643
you need to install drivers for you video capture device. I don't know what you mean by "built into PC", but even if it's part of the actual motherboard somehow, you still need drivers for it.
it sounds to me as though you forgot to install all your chipset drivers?
thebruiser
101
I used the driver disk that came with the pc. I don't know how the video capture is configured in the pc. Does anyone know if the wmd drivers from nvidia will actually cause problems if I install them?
thebruiser
101
It was the drivers. I contacted the pc manufacturer. They sent me the link to the "secret" site. Actually, I had to give them the serial number to the pc before I could d/l the drivers. Must be some kind of proprietary thing.
