need help
CraKaJaX
i'm just wondering, my case has 2x usb, mic, and speaker jacks on the front panel. I'm trying to hook them up but i don't understand the markings on them... they are all 1 pin connectors but are in group of 4. they are labeled: VCC, D-, D+, GND. What is VCC,D-, and D+? And where do I connect them? I have an A8n Deluxe mobo if this helps. There is another one but with only 3 wires on it labeled: L-ret, R-out, and L-out. I also don't know where to plug in the HDD LED connector on my mobo. I have looked in the mobo manual but it doesn't help at all really. I would appreciate some help, thanks 🙂
