Originally posted by: Idontcare
Originally posted by: DerwenArtos12
Originally posted by: Tullphan
Funny...I bought a pre-owned Tuniq & they forgot to send the controller. I figured if I hooked it up w/o it, it'd just run @ full speed plugged into the cpu fan port on my mb.
I replaced the fan w/a Y-L & the temps are higher.
I also noticed when I swapped out the fans that the old fan was blowing towards the front (if it was indeed running).
they probably just threw a jumper on the header for the controller. Thats what I used to do with thermaltake fans that required the fan speed controller or the thermal probe to be attached to run.
That's yet another stroker of genius by the Sunbeam crew...the speedcontroller conenction on the fan are the female end of the arrangement.
The male end of the connection (the one which can be shorted by a jumper) is on the manual speedcontroller end of the connection.
I know because I thought to attempt the same "fix-it" solution.
It is completely the opposite of the Thermaltake fans where the header on the fan comes already equipped with a jumper...they can do that because they intelligently designed the header on the fan to be the male connection.
