Need Help
kpxkirby
I just built a new computer. 3.0c, 1 gig of pc3200 corsair xms, gigabyte 8knxp, gf4 ti4200 128 megs, antec case and tru power 430 psu. One in a while, my computer will restart by itself. I thought it was the power supply because I had a powmax before, but it still restarts. Can anyone tell me what might be possibly wrong? Thanks.
maybe the drivers are bad...I once installed a lan card and the computer started restarting by itself time to time...
ah crap, i cant use that memtest program. It says I need to make a floppy diskette, but I dont have a disk drive. Does anyone know any other softwares I could possibly use, or what might be wrong? Thanks
how do I run it then?
This is the installation instructions:
Memtest86 is a stand alone program that cannot be executed under windows and must
be loaded from a floppy disk.
To install Memtest86:
- Extract the files from the zip archive
- Open the directory where the files were extracted and click on "install.bat".
- The install program will prompt you for the floppy drive and also prompt you to
insert a blank floppy.
- To run Memtest86 leave the floppy in the drive and reboot.
NOTE: After the boot floppy has been created you will not be able to read the floppy
from windows. This is normal.
Originally posted by: kpxkirby
I ran memtest, and got over 400 errors in about 2 hours. Is this common?
No, you should have no errors at all.... what do you have the memory timings and voltage set to?
Turn off any performance enhancement features on the board and try again. You might have faulty RAM. Is everything at default settings? Also might need a slight increase in VDIMM (2.7 or 2.75V, whichever your board lists giving preference to the lower).
