need help
skulls
i just got a kingston Pc2700 512mb 333Mhz...i can`t switch it to 333 in the bios... i use cpuid ,it display 266... i have a A7V333-X , i support 266 and 333... my cpu frequency is 13 as default.
what i can do ??? plz need help.
Jun 8, 2003
25
You might want to do one of several things one is that you could upgrade the bios. Another is you might be able to run the ddr slower? Hope I Helped.
pspada
2,503
You motherboard might only support the memory at 166/333Mhz if the CPU's FSB is set to 166.
