Need help...
blamb425
545
Ok, so after several STOP errors this past week, I ran memtest. I have two sticks of G Skill RAM, 1GB each, with an ASRock 4CoreDual-VSTA motherboard. Running memtest with BIOS - Std option, i got no errors. Then, when i switched to BIOS - All, I got so many errors the computer restarted itself on the third test...I then tried each RAM stick seperately, and got the same results. However, I got the same amount of errors with each stick, and when they were combined. On BIOS - Std, I got no errors at all. Is my RAM faulty?
Cerb
17,484
33
86
With the BIOS - Std option, everything works, right? In Windows (or elsewhere, like Memtest), does the RAM report running at the proper speed and timings? If it does, then the RAM is probably fine.
Does your BIOS give you manual RAM setting options?
What else does this BIOS - All option do?
If it's a "optimal" v. "agressive" v. "expert" kind of thing, leave it at optimal/failsafe/whatever (probably the Std), or go full on "expert" and mess with the individual settings, starting off with settings that are slower/looser than stock, just to be safe, and adjusting from there.
QuixoticOne
1,855
What is "BIOS STD" vs "BIOS ALL"?
This is the stand-alone MEMTEST program from here, right?
http://www.memtest.org/
I never recalled it had such options.
Just wanted to make sure you're NOT JUST running the BIOS BUILT IN
memtest which never will be enough of a test to give you total confidence
everything is working right, though it's OK for a quick check (obviously it SHOULDN'T
have errors).
Anyway I'd personally note down all your BIOS settings so you know
what to restore them to if needed, then physically turn off and UNPLUG the PC,
boot into BIOS, "Reset all settings to BIOS defaults", save that and exit,
pop back into BIOS and change all settings so your CPU / MEMORY / Motherboard
runs at 100% stock speed and stock voltage, nothing overclocked.
Run memtest86+ from CD and see if that works.
If not, try "Reset all BIOS settings to fail-safe defaults".
Test again.
If you still have problems, turn off the PC, use a blower to blow out all
the dust you can from the top/sides/bottom of the motherboard, the CPU,
the PSU, everything.
Physically remove the DIMMs, blow dust off the DIMMs and sockets,
look for cracks/corrosion/whatever, and reseat them carefully locking them in.
Reseating your CPU might eventually be called for but I'd do that as a last resort.
Check your PSU voltages with the BIOS built in hardware monitor and verify
that none of your 3.3, 5, 12 voltages are more than 5% too low or too high, ideally
within 2% or 3%.
Try with a new power supply of appropriate size to see if that helps.
If it's still not working with memtest, there's probably a hardware problem
and you should try to track it down to PSU, CPU, memory, motherboard, so you
can replace the defective thing.
