Ok follow these steps:
1)strip your mobo absolutely bare again (disconnect all cables, remove all cards, remove all RAM and remove cpu) and examine both your mobo and cpu closely to see if there any visible signs of damage (the cpu shouldn't be chipped in any way)
2)next, make sure that the mobo is properly grounded to the case. A stand off (plastic peg that isolates the mobo from the case) could have broken off causing the case to make direct contact with the mobo, subsequently preventing your comp from posting
3)next, reinstall your cpu (don't install the cpu heatsink or fan) and connect just the power supply cable to the mobo; don't install anything else (not even your vid card or RAM).
4)now start the computer. If you hear ANY beeps, that's a good sign as it means your cpu and mobo are probably ok; and you can go ahead and install your other components one by one until you encounter your beepless-boot problem, in which case you'll have then found your malfunctioning component. But if you don't hear ANY beeps, that almost definitely means either your cpu or mobo is dead; you wont know for sure which one it is unless you use another functioning cpu or mobo to isolate.
I'm guessing you might of shorted something out in your mobo when u dropped it, or your cpu was damaged somehow when the heatsink fell off. Another possibility would be damaged RAM, but if it was just that then you should at least be getting some kind of error beeps on post. Check out this
thread another guy had almost the same problem you're having.
