Need help writing an Unix AIX Script
jbloggs
I have a text file 'myfilelist 'in a unix directory (/tmp) that has a list of files including full path , e.g.
/usr/file1
/mydir/file2
/myapp/file3
I need a script (Unix AIX) that will read each of those lines from the myfilelist file and do an ls -al for each one. How can this be done using unix script?
TIA
There's no such thing as "unix script" you need to pick a shell in which to write the script. Normally this is one of bourne (/bin/sh), C (/bin/csh) or Korn (/bin/ksh).
I'm using /bin/ksh.
Thanks
Originally posted by: n0cmonkey
What have you got so far?
From looking around, I put together the following
for var in 'cat myfilelist'
do
'ls -al ' $var
done
This did not work as it gave me error that cat & myfilelist do not exist. I put the script in same dir as myfilelist.
do
'ls -al ' $var
done
You don't want to use single quotes around "cat myfilelist." In fact, you don't want quotes at all. 🙂
