Need help writing an Excel macro (I think)
BigToque
11,700
What I want to do sounds simple.
I have A1, B1 and C1.
C1 stores the value of B1 subtract A1.
What I want is for C1 to display 0 (zero) unless the result of the equation is > 1 (and to display the result)
Is this possible? Is it even a macro?
Len12345
41
its just an equation. Type =if and it will show you how to do it. The following will work for your above example.
=IF(A1>B1,A1-B1,0)
EDIT: that might be backwords but I hope you get the idea
