alanwest09872
Ok for those that are not fomiliar with xpadder. Its a software that allows you to keybind keys to a controller ex. xbox 360 pc controller (the one I am using).
Its a software that cost 10 dollars but you can download older versions for free. Now the downside is if you dont buy the software from xpadder if you download a free older version they dont allow you access to there website forums. So if you have a problem you sol for help from them. Thats where you guys come in (I hope lol)
Ok The problem I am having is that all the buttons work great accept the moving stick. If I attempt to move about 3-4 times a minute the stick (the one of the left) will get stuck and the toon will contiune running in one direction. Now the controller works fine in any other game that is programmed for actual controllers. So I know its not the left stick. Hardware wise it is working perfectly.
So I checked all the new versions and there is no fix for this so I figured there most be some setting that I have messed up. Oh the right stick works great I have that one programmed for the mouse movements and I havent had a problem yet.
Ok so the problem is xpadder causes the charater to move in one direction even after I stop pressing in that direction How do I fix this.
Recap
1. I have the xbox 360 pc controller
2. I am using Xpadder (allows keyboard and mouse binding onto a controller)
3. All hardware is 100 percent perfect
4. Software wise if I move forward after I stop moving my character it will continue moving in that direction till I hit the same direction again on the controller.
5. The game that I am using is Divinity 2 (great game so far)
6. I use left analog stick for moving (W,A,S,D Keys) right analog stick is for moving the camera (Mouse)
7. The controller works fine in all other games that come with the ability to use a controller. So it has to be the xpadder software.
What I have tried.
1. I have tried running different compatibility modes even though it works under windows 7 64bit
2.
Recap
What I have tried.
2.
