- Dec 3, 2000
- 344
- 0
- 0
Ok heres the situation:
I am trying to connect my Ipaq 3635 into a wireless network. I have the Linksys WCF11 compact flash network card. In my network i have connected a netgear me102 wireless access point.
First off i cant tell if i connected the access point correctly. All i did was install the software that came with it, plugged it into my hub, which is connected to my router, which is connected to my dsl modem. So i think i have that squared away.
Now as of my compact flash wireless card, im not too sure how to set this thing up. I installed the software, and i did plug it into the compact flash sleeve. But i cant seem to use pocket internet explorer. for some reason the only connections i can use for internet explorer are modems, i cant find my network card.
If someone, any1 can give me advice on this...i would greatly appreciate it.
