Need help with wireless home network
Shamrock
1,441
567
I have checked the forums and cannot find this problem.
I have 3 PC's hooked up on a WT624 Netgear Router, with 3 WG311T wireless cards (super 108MBPS) I created a wireless network on my router, and ALL 3 cards can see the network. But my PC's cannot communicate with each other! They connect to the router, but no connection to each other. I have tried bridging them, but to no avail there either.
I am experienced in PC's, but I am a newbie to networking. (my only fault with PC's)
Thanks
Shamrock
1,441
567
yes, file sharing, and LAN gaming...because we share game patches, and we game together.
Dogma420
make sure you share the hard drive with a share name, and make sure everyone can access it...make the name such as 'share$'....the $ means it is hidden unless someone can type it in first...map to that name as a drive share....
on each computer,
either on c drive or a folder, right click...make sure sharing is enabled...sharing name has a $ at the end...this share should have sharing and security tabs full rights to everyone (or specific names and pws)
That user's username and pw needs to be added to the computer (so technically if they logged into your computer they'd have the same rights)....
